Other Parts Discussed in Thread: BQ30Z55, BQEVSW, EV2400
I'm trying to change some voltage setting of a bq30z55.
I use EV2400 with BqEVSW v0.9.92, it connects with the chip fine, SBS page reads well, unseal and fully access.
But when I go to Data flash page, click "read all'', then a popup window said communication error, code=5. The lower left said VB_WRONG_NUM_BYTES.
So, I can't "write all" because the software said last read had error, writing abort.
Is there any other way to change number in data flash? I tried export the .gg file but the reading error also prevent import and write it.
Thank you!
