Other Parts Discussed in Thread: LM5145, LM5148, LM25148, LM5143, LM25143
My question is similar to those found in the following other threads:
- https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/971312/tps40170-paralleling-two-tps40170?tisearch=e2e-sitesearch&keymatch=TPS40170#
- https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/920981/tps40170-tps40170-can-supports-multi-phase-function?tisearch=e2e-sitesearch&keymatch=TPS40170#
Question(s):
Is it possible to connect two TPS40170's in parallel to provide power supply redundancy? If not, what is the intended use case for the "Sync" pin?
Details:
In our prototype design, we have two TPS40170 converters created. They are independent circuits except for the input voltage and output connection.
- They have independent feedback/compensation networks.
- They have independent switches.
- All other input pins other than Vin and the output from the inductor are independent.
When we run this combination only one of the converter's seems to be supplying the load (the master) and there is a terrible imbalance. Additionally, efficiency is reduced from what was achieved when using a single TPS40170. These results are consistent in simulation and in-lab testing.
With this information in mind, can anyone address the two questions I asked above?
