TPS6287B10: Thermal pad pin define
Part Number: TPS6287B10
Hi Team,
May I know the circled pin(thermal pad) in layout should connect to GND? Or it didn't need to connect any pin?
Also, may I know why the thermal pad is divided into three part instead of one big thermal pad?
Thanks.
Roy
Thanks.
Roy
  • Hi Roy,
    Yes, you must connect the thermal pads to GND and we recommend using vias to get the heat out:
    There is probably a manufacturing reason for having multiple pads, and this is common with larger packages.
    Chris
