Other Parts Discussed in Thread: UCC21750
Hi Expert,
Two questions would like to check with you.
- May I know the maximum supply current for VCC pin that customer should consider? I can only find the VCC quiescent current (4mA max). But not sure the max supply current for VCC.
- For the AIN, customer would like to use this pin to sense external thermal resistor. I saw there have internal current source for AIN. Just would like to double check with you that customer do not need external power supply for thermal resistor sensing.
Thanks!
Ethan Wen
