Does the power probe in PSPIce for TI work the same as the voltage probe and current probe? Every time I try using the power probe it doesn't work, when I go to add traces power is grayed out in the listing. Is there a setting somewhere for this? Can you explain how you can use the power probe on components in the schematic, specifically transistors/MOSFETs. Or can you point me where it explains how to use the power probe in. Trying to get power dissipation information on MOSFET used with LM5156 Flyback design in PSpice for TI.
PSPice for TIPSpice for TI power probe.docx
