Hi support team,
If a wrap-around voltage (0.5V to 5V) from an external circuit is input to the Vout side without energizing the Vin side, will the voltage on the Vin side become greater than 0V?
Dice-K
Hi support team,
Dice-K
Hi Dice,
No, our device has true shutdown function and will block current from both Vin and Vout. So the Vin will not be affected.
Travis
Hi Travis,
Thank you for your reply.
I think Shutdown mode is when Enable is Low.
Is Vin affected by Vout when Enable is High?
Dice-K
Hi Dice,
That depends on your bias voltage type. Is it a single-direction Voltage source that only output current or it's a bi-directional Voltage source that can sink current to clamp Vout?
Travis
Hi Travis,
I'm not sure which one, so please let me know about both cases.
Dice-K
Hi Dice,
It's hard to describe by words so I draw these figures.
For bi-directional clamping:
For single directional clamping:
Travis
Hi Travis,
Thank you for your great support.
Under the following conditions, if a wrap-around voltage (0.5V to 5V) from an external circuit is input to the Vout side, will the voltage on the Vin side be greater than 0V?
VIN = 0V
EN = High
Dice-K
Hi Dice,
If the Vin is 0V, the device will enter UVLO shutdown. So the result will be the same as EN=0 situation.
Travis
