TPS56837: How to treat the PG terminal when not using PG
Part Number: TPS56837
Hi team,
If the PG terminal is not used, is it okay to leave it open?
The datasheet mentioned "recommends a pullup resistor of 100kΩ to pull the PG pin up to 5V voltage". How is it In case when PG terminal is not used?
Taito Takemura
