Other Parts Discussed in Thread: UCC28070A, UCD3138, UCC28070
Hi
I'm Andy from Taiwan.
We try to design a dual AC input PSU.
The AC could be independent or two phases of three phase AC.
Do you have any suggestion??
Thanks.
Hello Andy,
Thank you for your interest in TI products. I do not think that your design will work well. You cannot simply tie multiple boost PFC outputs together. If you do, then your THD and PF will be poor. You need to track the current and phase of the AC input. Real world AC inputs will have common GND references so tracking multiple AC inputs will not work.
One possible solution is to have each AC input go into a separate PFC stage. Each PFC stage will then go into their own isolated DC/DC converter (Ex. an LLC or PSFB stage). The outputs of each isolated DC/DC converter can then be connected to each other. If you are using an analog controller, the UCC28070A is ideal since it has SYNC capability, which will be useful.
For 3-phase AC, you can use a UCD3138 or C2000 MCU in a 3-phase PFC, such as a Vienna Rectifier. Here is one such reference design: https://www.ti.com/tool/TIDM-1000
Please see the following E2E threads for more information
Jonathan Wong
