Hi related to my previous post, are there instructions somewhere about how to get the TPSI3050 model into Pspice and set up a simulation? Haven't seen any literature on it. Thanks, Dave
Hello Dave,
Thanks for your interest and reaching out to our team on E2E! Please take a look at this post, [FAQ] How Can I Simulate TPSI305x-Q1 Using Pspice for TI, and let me know if you have further questions.
Tilden Chen
Solid State Relays | Applications Engineer
Thanks Tilden, that was great for getting set up. Have followed those instructions, and simulation seems to run once, bur when I try to change a cap value (CVDRV), it always errors like below. Any idea?
Hello Dave,
I tried simulating with your settings but was unable to recreate the issue. I did a quick search and this seems like a PSpice For TI issue rather than an issue with our TPSI305x-Q1 model. Looks like if you select a different directory during installation rather than the default directory, this results in some sort of permissions issue that generates the error message you are seeing.
* This is the PSpice device and its parameters mapping file * * File Format of devParam.txt * Fields are separated by a space or tab. * * For Each record: * There are four fields on the line: <DeviceType> <noNamedParam>* NAMEDPARAMS: <namedParams>* * Where: * <DeviceType> is a device-type character. * <noNamedParam>* is a list of no-named parameters. * NAMEDPARAMS: is a key word. * <namedParams>* is a list of named parameters. * B C VALUE NAMEDPARAMS: IC D AREA NAMEDPARAMS: IC E F G H I DC ACPHASE NAMEDPARAMS: DC AC J K L VALUE NAMEDPARAMS: IC M Q R VALUE NAMEDPARAMS: TC1 TC2 S T U V DC ACPHASE NAMEDPARAMS: DC AC W Z
Was referring to this thread and this thread.
Tilden Chen
