Other Parts Discussed in Thread: LMR43620
Hello experts,
What is the operation of the LMR43620 in the event of an overvoltage?
Kentaro
Hello experts,
Kentaro
If the device experiences an OV event which passes the PG overvoltage threshold for a time long than the deglitch filter (both specified in the Specifications Section of the datasheet) then the PG pin will be asserted low until the output comes back into regulation.
Ridge
Hello Ridge,
Thank you for response.
When an overvoltage occurs, the PG terminal is set to Low, I interpreted that the output will not be turned off without permission, but is there one?
Kentaro
Hi Kentaro,
During an overvoltage event, the buck converter does not disable the output.
Ridge
Hello Kentaro,
Thank you. I will close this thread. If you have more questions you can re-open this thread by replying or create a new thread.
Ridge
