Other Parts Discussed in Thread: USB2ANY
Can you please provide the command for initializing LM36010 IIC? I haven't received any response after setting it for half a day.
Please provide detailed information and documents, thank you.
Hi Tonyx,
The most important setting is bit[1:0] in 0x01 register, which determines the mode of operation and the current setting register 0x03, 0x04, depending on flash or torch mode you are using. For others, you could leave default at the moment.
May I ask whether you are using the GUI or direct write/read register by USB2ANY?
Thanks!
Thank you!
