We have designed a USB-C charger using the TPS55288 chip, but we encountered an issue where two of our prototypes were damaged (both high-side and low-side MOSFETs were damaged and shorted) after a short circuit on the output. We plan to add a current sense shunt resistor to limit the current, but we are also considering whether a snubber circuit might be necessary?
Can you please review our schematic and PCB layout and provide feedback on any improvements to enhance short circuit protection and reduce EMI? For reference, please ignore the lack of a shunt resistor, as we know it needs to be added.
We are also wondering why the TPS55288's built-in hiccup mode did not prevent damage during the short circuit.
Also, since we need to monitor the current drawn from the buck converter using our microcontroller, we plan to use a current sense amplifier to read the voltage drop across the shunt resistor. Is there a better approach for current sensing in this scenario?
