Hi there,
I intend to use a TLC5951 as part of an RGB LED display. The screen would be made up of 8x8 pixel LED modules, each containing 64 RGB LEDs. The are connected internally in a common anode configuration. Basically, I would like to know if it is possible to use this chip to multiplex 8 rows of LEDs? This would mean that after every GSClk cycle, the next row of LED data would be loaded. Do you think this is a plausible solution? If not, do you have any other IC which may be suited to the job? I plan to use a TLC59213A or similar IC to source current and select the row.
