BYPASS Terminal on/off controlled by same as resister
We checked data sheet this function.
This AD Converter BYPASS Terminal on/off by this bit control.
「ADCONFIG:07h」-「VREF ENABLE:Bit4」
Any way, customer checked about this Bit Control .
This is Customer check result.
1) Case1: the voltage is supplied by the "AC terminal".
→ VREF dose not Controlled by this resister bit .
* Bypass can not control
2) Case2: the voltage is supplied by the "BAT terminal".
→VREF Controlled by this resister bit
* Bypass can control
[Question]
