Hi TI team,
Why does the TPS53219(A) datasheet specify an upper limit for the output voltage of 5.5 V?
What would be the implications of exceeding the 5.5 V limit by a few Volts? The input voltage is 19.5 V.
RG
Hi TI team,
RG
I don't support TPS53219 directly, but for other DCAP devices the maximum output voltage is limited by the adaptive on time controller.
Hi John,
Thanks for the explanation. The datasheet specifies a minimum off-time of 400 ns worst case. I can see that depending on switching frequency and input voltage, this limits the maximum output voltage. What I can still not see where that number of 5.5 V is coming from.
Even if I make assumptions about the operating conditions, like Vin = 12 V, f = fmax = 1 MHz, I am not getting to 5.5 V.
RG
