I want to use the LP5520 LED driver and we have problems to route a inner signal to the outside of the footprint.
A solution is to connect the SCL and the SO pin together. I use only the I2C interface (IFSEL=0).
In SPI mode the SO Signal is tristate when not in a read cycle (see page 23 of the datasheet).
Is it also tristate when the chip works in I2C mode only?
Thanks Klaus
