Pendularm 1 simulation Example of 1 DOF dynamics and control in HTML5/JavaScript and threejs
@author ohseejay / https://github.com/ohseejay / https://bitbucket.org/ohseejay
Chad Jenkins Laboratory for Perception RObotics and Grounded REasoning Systems University of Michigan
License: Creative Commons 3.0 BY-SA
<html>
<body>
<!-- ////////////////////////////////////////////////// ///// JAVASCRIPT INCLUDES ////////////////////////////////////////////////// -->
<!-- threejs - github.com/.../ --><script src="js/three.min.js"></script>
<!-- threejs camera controls helpers --><script src="js/OrbitControls.js"></script>
<!-- threejs keyboard input helper --><script src="js/THREEx.KeyboardState.js"></script>
<script>
/////////////////////////////////////////////////////// MAIN FUNCTION CALLS//////////////////////////////////////////////////
// initialize threejs scene, user input, and robot kinematicsinit();
// main animation loop maintained by threejs animate();
/////////////////////////////////////////////////////// INITIALIZATION FUNCTION DEFINITONS//////////////////////////////////////////////////
function init() {
// create pendulum object and its kinematic and dynamic parameters pendulum = {length:2.0, mass:2.0, angle:Math.PI/2, angle_dot:0.0};
// initialize pendulum controls pendulum.control = 0; pendulum.desired = -Math.PI/2.5; pendulum.desired_dot = 0;
// initialize integral term accumulated error to zero accumulated_error = 0;
// set gravity gravity = 9.81; // Earth gravity
// initialize pendulum PID servo gains pendulum.servo = {kp:0, kd:0, ki:0}; // no control
// initialize time and set timestep t = 0; dt = 0.05; // default // initialize method of numerical integration of dynamics //numerical_integrator = "euler"; //numerical_integrator = "verlet"; //numerical_integrator = "velocity verlet"; //numerical_integrator = "runge-kutta";
// OPTIONAL servo controller additional features steady_state_error_reset = false; // integral term resets after desired met servo_error_threshold = 0.001; // threshold for achieving desired servo_active_persist = false; // toggle to turn on servo controller servo_active_state = {}; // string with current state of servo activation
pendulum.previous_error = 0; //STENCIL: for verlet integration, a first step in time is needed verlet_first = 1; start = 1; // initialize rendering scene and user interface createScene();
/////////////////////////////////////////////////////// ANIMATION AND INTERACTION LOOP//////////////////////////////////////////////////
function animate() {
// note: three.js includes requestAnimationFrame shim // alternative to using setInterval for updating in-browser drawing // this effectively request that the animate function be called again for next draw // learningwebgl.com/.../ requestAnimationFrame( animate );
// switch between numerical integrators based on user input if (keyboard.pressed("0")) numerical_integrator = "none"; if (keyboard.pressed("1")) numerical_integrator = "euler"; if (keyboard.pressed("2")) numerical_integrator = "verlet"; if (keyboard.pressed("3")) numerical_integrator = "velocity verlet"; if (keyboard.pressed("4")) numerical_integrator = "runge-kutta";
// update servo desired state from user interaction if (keyboard.pressed("e")) { pendulum.desired += 0.05; start = 1; }// move the desired angle for the servo if (keyboard.pressed("q")) { pendulum.desired += -0.05; start = 1; } // move the desired angle for the servo
// add user force from user interaction if ( keyboard.pressed("d") ) pendulum.control += 50.0; // add a motor force to the pendulum motor else if ( keyboard.pressed("a") ) pendulum.control += -50.0; // add a motor force to the pendulum motor
// STENCIL: implement servo controller if (keyboard.pressed("c")) { servo_active_persist = true; servo_active_state = "active"; // pendulum.desired_true = pendulum.desired; pendulum.servo.kp =300; pendulum.servo.kd =150; pendulum.servo.ki =120; } if(servo_active_persist && numerical_integrator != "none") { /* if (start) { pendulum.desired_true = pendulum.desired; start = 0; } while (pendulum.angle > pendulum.desired_true + 2 * Math.PI) { pendulum.desired_true = pendulum.desired_true + 2 * Math.PI; // pendulum.angle_previous = pendulum.angle_previous - 2 * Math.PI; } while (pendulum.angle < pendulum.desired_true - 2 * Math.PI) { pendulum.desired_true = pendulum.desired_true - 2 * Math.PI; // pendulum.angle_previous = pendulum.angle_previous + 2 * Math.PI; }*/ var error = pendulum.desired - pendulum.angle; if(pendulum.previous_error == 0) { pendulum.previous_error = error; } if(Math.abs(error) < servo_error_threshold) { steady_state_error_reset = true; }// achieving desired else { steady_state_error_reset = false; accumulated_error += error *dt; pendulum.control = pendulum.servo.kp * error + pendulum.servo.ki * accumulated_error + pendulum.servo.kd * -pendulum.angle_dot; pendulum.previous_error = error; } }
// disable motor from user interaction if (keyboard.pressed("s")||!servo_active_persist) { pendulum.control = 0; accumulated_error = 0; start = 1; servo_active_state = "disabled"; } else servo_active_state = "active";
// integrate pendulum state forward in time by dt if (typeof numerical_integrator === "undefined") numerical_integrator = "none"; if (numerical_integrator === "euler") {
// STENCIL: a correct Euler integrator is REQUIRED for assignment var tmp1 = pendulum.angle; pendulum.angle = pendulum.angle + pendulum.angle_dot * dt; pendulum.angle_dot = pendulum.angle_dot + pendulum_acceleration(tmp1)* dt;
} else if (numerical_integrator === "verlet") {
// STENCIL: basic Verlet integration if (verlet_first == 1) { pendulum.angle_previous = pendulum.angle; pendulum.angle = pendulum.angle + pendulum.angle_dot * dt + 0.5 * pendulum_acceleration(pendulum.angle) * Math.pow(dt, 2); verlet_first = 0; } else { var tmp = pendulum.angle; pendulum.angle = 2 * pendulum.angle - pendulum.angle_previous + pendulum_acceleration(pendulum.angle) * Math.pow(dt, 2); pendulum.angle_previous = tmp; } } else if (numerical_integrator === "velocity verlet") {
// STENCIL: a correct velocity Verlet integrator is REQUIRED for assignment var a = pendulum_acceleration(pendulum.angle); pendulum.angle_previous = pendulum.angle; pendulum.angle = pendulum.angle + pendulum.angle_dot * dt + 0.5 * a * Math.pow(dt, 2); pendulum.angle_dot = pendulum.angle_dot + 0.5 * (pendulum_acceleration(pendulum.angle) + a) * dt; } else if (numerical_integrator === "runge-kutta") {
// STENCIL: Runge-Kutta 4 integrator } else { pendulum.angle_previous = pendulum.angle; pendulum.angle = (pendulum.angle+Math.PI/180)%(2*Math.PI); pendulum.angle_dot = (pendulum.angle - pendulum.angle_previous) / dt; numerical_integrator = "none";
pendulum.control = 0; accumulated_error = 0; start = 1; } // set the angle of the pendulum pendulum.geom.rotation.y = pendulum.angle; // threejs cylinders have their axes along the y-axis
// advance time t = t + dt;
textbar.innerHTML = "System <br> " + " t = " + t.toFixed(2) + " dt = " + dt.toFixed(2) + "<br>" + " integrator = " + numerical_integrator + "<br>" + " x = " + pendulum.angle.toFixed(2) + "<br>" + " x_dot = " + pendulum.angle_dot.toFixed(2) + "<br>" + " x_desired = " + pendulum.desired.toFixed(2) + "<br><br> Servo: " + servo_active_state + " <br> " + " u = " + pendulum.control.toFixed(2) + "<br>" + " kp = " + pendulum.servo.kp.toFixed(2) + "<br>" + " kd = " + pendulum.servo.kd.toFixed(2) + "<br>" + " ki = " + pendulum.servo.ki.toFixed(2) + "<br><br> Pendulum <br> " + " mass = " + pendulum.mass.toFixed(2) + "<br>" + " length = " + pendulum.length.toFixed(2) + "<br>" + " gravity = " + gravity.toFixed(2) + "<br><br> Keys <br> " + " [0-4] - select integrator " + "<br>" + " a/d - apply user force " + "<br>" + " q/e - adjust desired angle " + "<br>" + " c - toggle servo " + "<br>" + " s - disable servo "
// threejs rendering update renderer.render( scene, camera );
//function pendulum_acceleration(p,g) {function pendulum_acceleration(angle) { // STENCIL: return acceleration(s) system equation(s) of motion return (-gravity / pendulum.length * Math.sin(angle) + pendulum.control / (pendulum.mass * Math.pow(pendulum.length, 2)));}
function createScene() {
// instantiate threejs scene graph scene = new THREE.Scene();
// instantiate threejs camera and set its position in the world camera = new THREE.PerspectiveCamera( 75, window.innerWidth / window.innerHeight, 1, 10000 ); camera.position.y = 1; camera.position.z = 4;
var light1 = new THREE.PointLight( 0xffffff, 0.3, 1000 ); light1.position.set( 10, 10, 10 ); scene.add( light1 );
var light2 = new THREE.PointLight( 0xffffff, 0.3, 1000 ); light2.position.set( 10, -10, 10 ); scene.add( light2 );
var light3 = new THREE.PointLight( 0xffffff, 0.3, 1000 ); light3.position.set( -10, -10, 10 ); scene.add( light3 );
var light4 = new THREE.PointLight( 0xffffff, 0.3, 1000 ); light4.position.set( -10, 10, 10 ); scene.add( light4 );
// instantiate threejs renderer and its dimensions renderer = new THREE.WebGLRenderer(); renderer.setSize( window.innerWidth, window.innerHeight );
// attach threejs renderer to DOM document.body.appendChild( renderer.domElement );
// instantiate threejs camera controls camera_controls = new THREE.OrbitControls( camera ); camera_controls.addEventListener( 'change', renderer );
// instantiate threejs keyboard controls, for continuous interactive controls keyboard = new THREEx.KeyboardState();
textbar = document.createElement('div'); textbar.style.position = 'absolute'; //textbar.style.zIndex = 1; // if you still don't see the label, try uncommenting this textbar.style.width = window.width-10; textbar.style["font-family"] = "Monospace"; textbar.style.height = 20; //textbar.style.backgroundColor = "black"; textbar.style.color = "#000000"; textbar.innerHTML = "M4PRoGReS - pendularm!"; textbar.style.top = 10 + 'px'; textbar.style.left = 10 + 'px'; document.body.appendChild(textbar);
temp_geom = new THREE.CylinderGeometry(0.2, 0.2, 3.5, 20, 20, false); temp_material = new THREE.MeshLambertMaterial( { } ); temp_material.color.r = 1; temp_material.color.g = 1; temp_material.color.b = 1; temp_material.color.b = 1; temp_material.transparent = true; temp_material.opacity = 0.3;
leg1 = new THREE.Mesh(temp_geom, temp_material); leg2 = new THREE.Mesh(temp_geom, temp_material); leg3 = new THREE.Mesh(temp_geom, temp_material); leg4 = new THREE.Mesh(temp_geom, temp_material); leg1.position = {x:2,z:1,y:0}; leg2.position = {x:-2,z:1,y:0}; leg3.position = {x:-2,z:-1,y:0}; leg4.position = {x:2,z:-1,y:0}; scene.add(leg1); scene.add(leg2); scene.add(leg3); scene.add(leg4);
temp_geom = new THREE.CylinderGeometry(0.2, 0.2, 4.0, 20, 20, false); sidebar1 = new THREE.Mesh(temp_geom, temp_material); sidebar1.rotateOnAxis(new THREE.Vector3(0,0,1),Math.PI/2); sidebar1.position = {x:-2,z:0,y:1.5}; leg1.add(sidebar1); sidebar2 = new THREE.Mesh(temp_geom, temp_material); sidebar2.rotateOnAxis(new THREE.Vector3(0,0,1),Math.PI/2); sidebar2.position = {x:2,z:0,y:1.5}; leg3.add(sidebar2);
temp_geom = new THREE.CylinderGeometry(0.2, 0.2, 2.0, 20, 20, false); crossbar = new THREE.Mesh(temp_geom, temp_material); crossbar.rotateOnAxis(new THREE.Vector3(1,0,0),Math.PI/2); crossbar.position = {x:0,z:-1,y:0}; sidebar1.add(crossbar);
temp_geom = new THREE.CylinderGeometry(0.3, 0.3, 0.3, 20, 20, false);
temp_material = new THREE.MeshLambertMaterial( { } ); temp_material.color.r = 1; temp_material.color.g = 0; temp_material.color.b = 0; temp_material.transparent = false;
pendulum.geom = new THREE.Mesh(temp_geom, temp_material); pendulum.geom.rotateOnAxis(new THREE.Vector3(1,0,0),Math.PI/2); //crossbar.add(pendulum.geom); scene.add(pendulum.geom); pendulum.geom.position = {x:0,y:1.5,z:0};
temp_geom = new THREE.CylinderGeometry(0.2, 0.2, pendulum.length, 20, 20, false); pendulum_link = new THREE.Mesh(temp_geom, temp_material); pendulum_link.rotateOnAxis(new THREE.Vector3(1,0,0),-Math.PI/2); pendulum_link.position = {x:0,z:pendulum.length/2,y:0}; pendulum.geom.add(pendulum_link);
temp_geom = new THREE.SphereGeometry(Math.sqrt(pendulum.mass*0.1)); pendulum_mass = new THREE.Mesh(temp_geom, temp_material); pendulum_mass.position = {x:0,y:-pendulum.length/2,z:0}; pendulum_link.add(pendulum_mass);}
</script></body></html>
