Hi Team,
My customer want to double check some normal voltage on critical pins to verify it's normal working status during production and test, can you help double check,
Customer want to know the normal voltage on SS pin, RT pin and time pin. Thanks a lot!
Hi Team,
Can you help have a look and double check this, thanks a lot!
Sulyn Zhang
Hi Peter,
Thanks, can you help check when I can got some feedback from team? Thanks.
Sulyn Zhang
Hi Wangxin,
Thanks for the support. But I think you misunderstanding my question. Customer want to know the normal voltage on these three pins(SS pin, RT pin and Time pin) when normal working to make sure LM5025A works normally in customer's case, but not abs max voltage which already showed in the datasheet. Can you help check this, thanks a lot!
Sulyn Zhang
Sulyn,
During steady state operation,
SS should be around 5V, not sure about RT pin and time pin. I searched through the datasheet, EVM user guide but couldn't find the steady state waveforms for these pins.
Can you please order a LM5025A EVM to look at the waveforms on these pins? The EVM can be ordered from ti.com, http://www.ti.com/tool/lm5025aeval#buy or purchased from a distributor, for example, https://www.digikey.com/products/en/development-boards-kits-programmers/evaluation-boards-dc-dc-ac-dc-off-line-smps/792?k=lm5025a
Wangxin
