Other Parts Discussed in Thread: TPS561201, INA199, LM321, LMV431
I would like to add another circuit as the attached rough schematic in order to limit the current of tps54228 to 1A. I assumed that it will influence sw pin by that but it doesn't affect the current operation of the ic after a few tests.
Please advice is this implementation on sw pin is correct? or if not, how can I use this feedback circuit with other pin# or add other configuration feedback to limit the current?
Thank you,
