Other Parts Discussed in Thread: TPS22917, TPS22918
On my board, i have a supply line that can be also used as an external output voltage. I'm using a TPS22860 to protect this line. But i have residual voltage remaining on VOUT line when i'm setting off the TPS22860 and i don't know why. This residual voltage implies some current consumption on the load put after my TPS22860. Do you think i can put a pull down resistor on VOUT (in red on my scheme) ?
If you think there is a better component for my application don't hesitate to share ?
Thank you in advance for your help :)
