Other Parts Discussed in Thread: BQ50002
The problem occurs when I use bq50002EVM-607 or BQ500511+BQ50002:
After the battery is fully charged, the green LED on the power transmitter lights up:
And then, I repeat the following steps for several times: removing the power receiver for a short distance -> puting the receiver back on the transmitter -> removing -> putting back......
During above process, the green LED which indicates fully charged keeps lighting.
At last, I remove the power receiver completely, the green LED keeps lighting for 10+ seconds, and then off:
The green LED should be off immediately after the receiver is away, right?
If there's something wrong?
