We are evaluating PWM-Only dimming for a new LED driver design using the EVM module. We configure the EVM as a buck-to-battery converter. Power in = 19V. Current range: 0 -700mA. Vout at 700mA = 10V. Sw Freq = 600kHz
For any output current above about 100mA, the duty cycle at the switching node is about 50% when PWM is ON. This is expected. .However, as the PWM Duty Cycle is further reduced, the duty cycle at the switching node quickly increases to almost 100% and the output current rises to about 140mA. As the PWM Duty Cycle is further reduced, the current decreases from 140mA to zero.
Exactly the same behavior occurs if the PWM Duty Cycle is increased from 0. What is causing this "peaking" of output current at 140mA?
We are using 20kHz for the PWM Frequency. We tried 2kHz and found that the peak is still there but it occurs at about 14mA (factor of 10 lower current). We would like the current to decrease monotonically (not necessarily linearly) to 1mA. Is there something we can do to achieve that?
I can send scope photos if necessary.
Richard
