TL750M: Input Capacitance Value
Part Number: TL750M
Hi team,
My customer uses TL750M08CKVURG3 and asked me below questions.
If you have any comment or advice, please let me know.
  • Could you please provide recommended effective input capacitance value for TL750M08?
    Currently I will recommend > 0.1uF ceramic capacitor.
    Is this all right?
  •  Is it possible to share input capacitor of TL750M08 with another LDO(NJM7805DL1A)?
 Warmest regards,
Shota Mago
  • Hi Shota,
    Input capacitor affects the transient performance of the linear regulator. Datasheet electrical characteristics were measured with a 0.1 uF input capacitor. I would recommend 0.1 uF minimum and 1 uF typical. A larger value can also be used.
    If the TL750M08 and NJM7805DL1A are close together on the board, the input capacitor can be shared. Try to place the input capacitor within 1 cm of the TL750M08 Input pin.
  • Hi Eric-san,
    Thanks for your quick response.
    I've got your advice and will report to the customer.
    Again, I appreciate your support.
    Shota Mago
