TINA/Spice/LM4040: Spice Model of LM4040
Part Number: LM4040
Other Parts Discussed in Thread: TINA-TI,
Tool/software: TINA-TI or Spice Models
I would like you to confirm about below.
* I am tring to simulate positive and negative voltage by using LM4040 TINA-TI model.
Here are simulation result of each model.
I observed expected result in case of Positive constant voltaeg circuit. However, I could NOT observe expected result in case of Negative voltage circuit.
Attached two files TINA simulation model.
Q1. If there is any incorrect portion to simulate negtive rail, could you please let me know.
Q2. Another person try to simulate this by using LT-Spice(use PSPICE model). However, they got same result. So, I suspect simulation model may not be correct.
Could you please confirm simulation model as well ?
LM4040_Pos.TSCLM4040_Neg.TSC
