Other Parts Discussed in Thread: LM3281
Hi Team,
I understand output voltage of LM3241 can be set by VCON pin.
I believe it isn't possible to be set by resistor divider at FB pin instead .
Is my undrstanding correct?
The background of the question is there is no DAC and another stable power supply in my customer's system, so would like to ask just in case.
My customer wants to adjust Vout around 3.3V and smaller solution that supports 250mA is required in this case.
Note) LM3281(fix 3.3V) can't be adjust.
Yaita
