Other Parts Discussed in Thread: LM5022, TPS43060
When LM3478 has no load, it enters hopping mode, if output voltage exceed OVP threshold, output will be disabled, which leads to output voltage go down until hit hysteresis bottom voltage. A voltage ripple with 2 votes will be generated. Is there a way to avoid this situation? If not, can I use LM5022 to alleviate? If LM5022 is not going to fix, any other IC works?
