TPS23755EVM-894: TPS24755EVM 5V output
Part Number: TPS23755EVM-894
Other Parts Discussed in Thread: PMP9175, TPS23755
Hi team,
May I know if customer would like modify TPS24755EVM to 5Voutput, can customer just change R16/R21 value? or other components also need to change?
Thanks & regards
Eddie
  • Eddie, You have entered a question over the weekend so E2E coverage is light.
    Our PD expert will review this on Monday, US time.
    Thank you for your local promotion and support of PoE products from Texas Instruments,
  • Hi Eddie,
    The TPS23755 is not optimized for a 5V output. It is intended for 12V diode rectified designs. Instead, we recommend our 5V/2.3A PMP9175 design.
    In addition to changing that voltage divider ratio, the transformer would need to be changed for the appropriate turns ratio for 5Vout.
    Tom Amlee
    PoE PD Apps Engineer
