Dear Sri/Ms.
1. When the action is normal operation, the 19pin Duty will be big and small. As shown in the attached picture.
2.Protection testing. Remove the LED string and test if there is any action, but found that TPS92692 burned out. Test resistance grouping,
It was found that the CSP exhibited a low impedance state. The hook FLT Pin3 has a pull LOW, and the measured CSP (R37) voltage is only 40V. Customer try to change the switching frequency 200Khz, and adjust the switching frequency up to 400Khz. TPS92692 still burned.
Excuse me, would you please guide us? How to solve this bug?
Kami Huang
