LM5069: dV/dt Start-up
Part Number: LM5069
In the application circuit as below red color, there is a dV/dt startup circuitry. Could you guide me when it should be used and how to select the capacitor value for good startup during operation? Is there any calculation formula? Thanks.
Brian
  • Hi Brian,
    The dVdt circuit is needed to control inrush current while starting a large capacitive loads. It should be selected based on the target inrush current and Cout value.
    Iinrush = Cout * dVout /dt
    The dVdt capacitor sets the dVout /dt rate as follows
    Igate = Cdv/dt * dVout /dt      ==>        Igate = Cdv/dt * Iinrush / Cout
    I suggest to use design calculator http://www.ti.com/product/LM5069/toolssoftware to calculate Cdv/dt value.
    Best Regards, Rakesh
