Other Parts Discussed in Thread: LMR14020
Hi Team,
May I ask whether TPS61085 has the hysteresis voltage?
My customer wants to consider using TPS61085. However, the Vin of TPS61085 comes from Battery. The battery voltage may not be very stable and sometimes may have pulse. When EN connect with Vin, because of the pulse or noise from Vin, the voltage of EN may be Low/High/Low/ High...
However if use the LMR14020's EN, which has Enable and Adjustable Under-voltage Lockout, this can be avoided. And Enable won't be influenced by pulse and noise...
As for TPS61085, do we have such function to avoid pulse and noise impact?
Thanks!
