Hi all,
We are now using TPS54360(not TPS54360B), and found that Pin SW was short to GND when powered on about several hours.Damage ratio is about 1~2%,a big trouble.
The schematic like this:
The maximum output current we used is 1.5A, we tested up to 3A for 1 hour after mount a new IC,not damaged,we test it in normal output current 0.5A for several days,still not damaged.
We also analysis the waveform of SW Pin and ripple of output voltage , not bad we thought.
SW PIN:
VOUT :
Ripple of VOUT:
Please kindly help me troubleshoot this issue.
Thanks and regards!
