TPS23753A: if TPS23753A supports non-isolated application?
Part Number: TPS23753A
HI team,
if  TPS23753A  supports non-isolated application asTPS23750 , I have not found in datasheet.
Thanks.
BR
Sara
  • Hi Sara,
    Thank you for your question.
    Yes, the TPS23753A can be used in non-isolated applications. You can take a look at our PM40355 reference design which uses the TPS23753A in a class 3 non-isolated design: http://www.ti.com/tool/PMP40355
    If you would like to provide the system level specifications for this design (output voltage/current, key care abouts: size, cost, efficiency, etc.) than I may be able to help recommend a reference design to meet your system level needs.
    Please let me know if you have any questions.
    Thank you!
    Brett Colteaux
    PoE Product Marketing Engineer
