I want to understand the calculations that are needed to determine the cell voltage sensing (VCx pins) filter capacitor value. As per the Design example, the resistance value Rin is calculated from the charge taper current but how to determine the filter capacitor.
Also the recommended value for filter capacitor with internal cell balancing is specified as 1microF and the capacitor value with external cell balancing is specified as 0.1microF in the datasheet. But, the design example having internal cell balancing is set to have filter capacitor of 0.1microF. This is confusing.
Request to explain this in more detail.
Shivani Ghorpade
