Other Parts Discussed in Thread: LM76003
Hi team,
Our customer is interested in an inverting step-down converter using LM76003. In PSpice, I tried to connect the Vout to the ground and the GND pin as the Vout. And from the simulation result, I get the negative output voltage I need.
However, I'm not confident enough if I could do that directly in the EVM. What will happen if I connect Vout to the ground and connect GND pin as the Vout in LM76003EVM? Will there be a short circuit or It could operate normally and I get a negative Vout?
Thank you so much for your help.
BR,
Yuhang Yan
