My customer used LM3671TLX-ADJ before, and its maximum output voltage is 3.3V. Can it run under output voltage=3.7V ,half-load?
If not, can you recommend chips that can replace it?(Customer has finished the sample and wants to be as close to LM3671TLX-ADJ as possible with fewer modifications)
Thank you
