Other Parts Discussed in Thread: , TPS65916, AM5706, LP873220
Hi team,
I have 3 questions like below.
- According to the post of https://e2e.ti.com/support/power-management/f/196/p/830546/3072845, LP87332D and LP873347 are same except OTP programming.
I found the OTP setting of LP87332D for AM570x in the following link however, I couldn't find the OTP setting register of LP873347 as 0x2D and 0x20.
Does LP873347 have a OTP setting register for AM570x?
https://www.ti.com/lit/ug/snvu554a/snvu554a.pdf - Is LP873347 able to automatically activate a startup sequence like Figure2 of the above document when power is input?
Also, I would like to know initial register of OTP_EPROM if the register is initially written for AM570x. - In regards of TPS659163 and LP8733, my understanding is TPS659163 can be implemented by only 1 device for AM570x but LP8733 needs 2 devices (LP8733+LP8732), is that correct?
Is there any good points by using TPS659163?
Koyo
