DATASHEET said as follows:
Once the high-side switch current limit is reached, the high-side switch is turned off and low-side switch is turned on to ramp down the inductor current with an adaptive off-time.
I have one simple question. Is "Current limit" checked on every switching frequency? Also, Does the current return to normal operation if the current falls below the current limit? timing from Current limit situation to normal operation. Please advise us.
Thanks and best regards,
M.HATTORI
