Other Parts Discussed in Thread: TPS2121
I want to read out the status of the ST on an 3.3V microcontroller. The datasheet seems to imply the ST pin is open drain, so I can simply use a internal (3.3V) pull-up of the microcontroller. Is this true? Or does the TPS2120 drive/pull its ST line high (and to which voltage)?
