Other Parts Discussed in Thread: TPS62826
Hi Sir,
In my knowledge , L value should change to the bigger one , but the result shows change to smaller one is correct.
Could you give me some advices?
If your thought is same as my test result , please teach me the fundamental.
please kindly let us know if there any risk, if the inductor 1u change to 0.47u.
Test purpose:
At low input voltage(3.036V)
Change L1 & C3 then test the output Vp-p , target to lower than 156mV.
But we found the effect of 0.47uH is better than 2.2uH , this result is different to my knowledge.
in the current mode of TLV62585, the inductor value reduce, can the output ripple be reduced?
If your thought is different as my test result , maybe I have to do extra test.
