Hi team.
Could you kindly give the reference design for LM5181 for the below specifications:
Input: 18-40V (typ=24V)
Output:
1) 32V, 0.05A;
2) 24V, 0.05A;
3) 5V, 0.05A.
Most interested in turns ratio.
According to table 3 of the LM5181 Datasheet for 16-32V the turns ratio should be 1:2.
However, the "LM5181 PSR flyback converter design tool" (https://www.ti.com/tool/LM5181DESIGN-CALC) does not allow you to set this turns ratio 1:2 (or 1:1.5; 1:3; 1:4). The program crashes.
Can you provide a "LM5181 PSR flyback converter design tool" for calculating the turns ratio 1:2?
Thank you and best regards,
Vyacheslav
