For this circuit, we have 5v i/p and 3.3v o/p is required. Only on one board, there is a problem that we are getting 1.3v at the SW pin. And at the FB pin 0.462v. Also, what is the internal feedback resistors value?
Hello Vanaraj,
Can you replace the TPS62063DSG on the failed board with a new sample? This is to ensure that the device is working properly.
I s the VOUT regulating properly with the new part?
Excel
Yes, we replaced IC but then also in o/p, we are getting 1.229v at SW, 1.09V at FB and at fuse 1.1v
Thanks & Regards,
Vanaraj
Hello Vanaraj,
Thanks for the quick response.
Can you disconnect the fuse and measure the output again? If the Vout is still not regulating properly, then please measure the VIN, VOUT and inductor current and post the waveform here.
Excel
Hello Vanaraj,
Do you have any update on the requested waveform?
Thank you.
Excel
Hello Vanaraj,
Any update on the requested waveform?
Thank you.
Excel
Hello Vanaraj,
If you don't have further queries, I will close this thread. Feel free to post your questions to re-open it.
Excel
