Other Parts Discussed in Thread: TPS43060
I just received the eval board yesterday afternoon. I hook it up this morning with 18V/5A input power supply and 15 Ohms resistor and the circuit got stuck into some hiccup mode.
Hi Chien,
Thanks for reaching out with your question and for considering the TPS43060 in your design.
I looks like the current limit of your power supply might be getting tripped. 5A is too low to power the 40V output when loaded with 15 Ohm. Please tyr using a power supply that has a larger current capability. A 10A supply should be adequate.
Garrett
