The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS552882: TPS552882 switching frequency setting
Part Number: TPS552882
Other Parts Discussed in Thread: LM5145
Hello Team,
The customer would like to confirm whether TPS552882 support the following operation.
To be specific, at first TPS552882 is turned on by the internal clock (frequency setting by SFW pin), then FPGA starts operating and outputs an external SYNC clock, after that LM5145 operates in synchronization with the external clock from FPGA.
Is it possible to operate above using TPS552882?
Your advice would be so appreciated.
Best Reagrds,
Akihisa Tamazaki
