LMR14010A: Is LMR14010A is suitable for variable output voltage
Part Number: LMR14010A
I'm trying out something on LMR14010A. Is this device is suitable for variable output voltage? If don't use feedback resistor output voltage is variable?
  • Hi Shivaraj,
    LMR14010 use feedback resistor to set the output voltage, the output voltage can be adjusted by bias the FB point with control voltage through a proper resistor.
    this device has no other interface to adjust the output voltage.
    B R
    Andy
