TPS22954: Sequence requirements of IN, BIAS and EN pin
Part Number: TPS22954
Hi, Support team
The customer circuit is designed as below. EN is controlled by CPU.
The voltage on EN pin is always kept to more than VIH(0.7V), but the voltage on IN pin and BIAS pin is suddenly shutdown and is recovered.
In that case, is the output voltage appeared correctly? I would like to know if there are any sequence requirement of IN, BIAS and EN pin.
Tamio
