Hello team,
customer is using BQ24192 in his schematic and wants to use single thermistor ,
can he short ts1 and ts2 and connect it to the center point between the resistance and thermistor ?
is this a valid condition .
Customer also mentioned a case when the charging the battery is happening perfectly fine however the charge indicator pin does not blink .
The solution to this issue comes out by shorting TS1 and Ts2 and connecting it to a valid resistor divider , is this expected ?
