Hi Tom,
The datasheet shows that connect a 24.9k ohm resistor from DEN to VDD.
But we asked you before, and I suggest we can connect a 27.4k ohm resistor from DEN to VDD.
Could you kindly explain the reason we should modify it?
Because the sifod test show Rdet, Rdet_final, Rdet_at_Vmin and Rdet_at_Vmax are fail.
I think it is because this modification cause test fail.
