Other Parts Discussed in Thread: UCD7138,
when I use UCD3138A to control the synchronous rectifier with the UCD7138 driver, the PWM signal send to IN pin is based on the phase with primary. which means the turn-on of the IN pin is decided by the primary PWM which is controlled by PWM0, I don't want to use the primary information, can I use the controller only based on the secondary information.
