Part Number: 66AK2H12
Other Parts Discussed in Thread: SYSBIOS, CCSTUDIO
Would you please provide a "Quick start Guide for K2H - EVM " to enable a quick product development ?
Quick start Guide for K2H-EVM
Introduction:
This Master-FAQ document will help to explore the functions and features of K2H - Processor device using the K2H (EVM) with SDK. Going through these FAQ-list will help the customer to get good hands-on experience on the K2H -EVM and help for a smoother and quicker navigation to their customized product development.
A |
No Functionality |
F |
Reserve for factory programming |
B |
1 press: safe shutdown of SOC; 4 presses with 0.5 sec: cancel reset |
G |
MCU Reset Jumper for BMC field update |
C |
COM2: SoC UART Console |
H |
Dip switch for boot configuration: 0001: No Boot/JTAG DSP Little Endian Boot mode 0010: NOR SPI Boot |
D |
COM1: MCU UART Console |
I |
Provide 2 console ports in USB interface ( same as “C” and “D”) |
E |
J |
MCU Reset: Resets the microcontroller and will reset the entire board |
Content-List
For hassle-free experience, user is requested to follow the steps sequentially
How to run the K2H EVM’s out of box demo.
---- Please downoad and follow the instructions and the connection settings given in the quick start guide below.
ARM -SIDE : ( Linux )
DSP -SIDE : ( RTOS ) And ARM - SIDE : ( SYSBIOS based RTOS - ( Non-Linux) )
1. The Latest Linux SDK –
There are many versions of Linux SDK released for K2H processor. When this document is written, this is the latest.
SDK NAME - PROCESSOR-SDK-RTOS-K2HK 06_03_00_106
Download link - https://software-dl.ti.com/processor-sdk-rtos/esd/K2HK/latest/index_FDS.html
For older versions of SDK, click "view-all-versions" in the above link and download from here : ://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-K2H
Please ensure, the revision number of K2H -EVM matches with the SDK revision.
2. Make use of the Linux SDK and K2H EVM ---
1.The Latest SDK –
There are many versions of SDK released for K2H processor. When this document is written, this is the latest.
SDK NAME - PROCESSOR-SDK-RTOS-K2H 06_03_00_106
Download link - http://software-dl.ti.com/processor-sdk-rtos/esd/K2H /latest/index_FDS.html
For older versions of SDK, click on previous versions in the above link or download from here : .https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-K2HK
2.The (IDE) Integrated development environment –
As the PROCESSOR-SDK-RTOS-K2H 06_03_00_106 is tested to run successfully in CCS version 9.3.0.00012 without any errors, the users are recommended to stick to this CCS version.
However, the user, may use, the higher versions of CCS, as their own choice. TI could not guarantee solution, if errors faced while using in-compatible versions of CCS with SDK.
IDE NAME - CCSTUDIO_9.3.0.00012
Download link - www.ti.com/.../9.3.0.00012
4.How to make use of the SDK with IDE and EVM
4.a) How to generate the CCS-based PDK examples. -- For both ARM core and DSP core
4.b) How to set the development environment and establish the connection between the EVM and the development-PC.
How to create "Target configuration" and do "Test connection" on K2H EVM
How to load and run the DSP gel file on K2H EVM
How to load and run the ARM gel file on K2H EVM
4.c ) How to run the UART example on the K2H EVM ( DSP core ) ?
4.d ) How to run the UART example on the K2H EVM ( ARM core ) ?
[FAQ] 66AK2H14: UART ARM PROJECT - Processors forum - Processors - TI E2E support forums
Other Important Links and resources
K2H - EVM
Where to buy : http://www.ti.com/tool/evmk2h ( This link is under verification )
Schematics and other hardware docs: https://www2.advantech.com/Support/TI-EVM/EVMK2HX_sd.aspx
K2H Processor:
1. About the functions and features of K2H processor - Product folder : https://www.ti.com/product/66AK2H12
2. Where to order : https://www.ti.com/product/66AK2H12#order-quality
3. Data sheet : https://www.ti.com/lit/ds/symlink/66ak2h12.pdf
4. Technical documentations - https://www.ti.com/product/66AK2H12#tech-docs
5. Design and Development : https://www.ti.com/product/66AK2H12#all
Software - https://www.ti.com/product/66AK2H12#software-development
Hardware - https://www.ti.com/product/66AK2H12#hardware-development
6. If you have questions about quality, packaging or ordering TI products, see TI support.
7. To post a technical query on E2E Forum: (+) TI E2E support forums
Shankari G
