AM6442: AM64x power supply and compatibility
Part Number: AM6442
Other Parts Discussed in Thread: AM6421
Hello, I have questions about AM64x.
Question 1:
AM64x VDD_CORE can be selected from 0.75 or 0.85V. Is this determined by the model number? Could you tell me the difference between them?
Question 2:
VDDS_DDR can be selected from 1.1 or 1.2V. Is this determined by the DDR used?
DDR4:1.2V
LPDDR4:1.1V
Question 3:
Is it possible to replace the AM64x series without change because it is pin compatible?
My customers designing with AM6442 are considering  and replace it with AM6421.
Rei
  • No, all devices will operation with either 0.75 or 0.85V VDD_CORE.  There are several other voltage rails which require 0.85V, so you can either combine all those rails for a simplified power solution, or you can implement VDD_CORE=0.75 to reduce power consumption
    Yes, DDR type will determine the DDR IO voltage VDDS_DDR
    Yes, these device variants are pin compatible
    James
  • Thank you very much!
